September 8, 20206 yr Hi Does anyone have experience setting up this particular machine. Purchased a bundle offer from a company for my parents home and had it setup but the inverter does not switch over to battery when Eskom is down. Before returning the machine I just wanted to find out other experiences with the Deye inverter as we have failed at every turn to figure this thing out. Plus my folks are old school so they on my case. How could I get something so expensive that does not work...eish.
September 8, 20206 yr You will need to post some of the screens to see what they are. I have a sunsynk with the only real difference being the UI.
September 8, 20206 yr Author Hi The battery is a Pylontech 3000. The inverter reads all the info in regard to the battery. Charges it ect. It just does not switch over to the battery when Eskom goes out. The inverter stays on. You can here it click inside but no power output when it supposed to change over.
September 9, 20206 yr Author Ok sorted, brand new inverter faulty from the box, confirmed by support guys. Supplier organising return.
