Pylontech us3000b error led
Hi, I am running an Axpert 5kva  and two pylontech us3000 as a backup in case of load shedding.  System is in standby but i randomly get the  warning light on the master battery coming  on ,does not flash. If I switch the battery off and on again it seems to reset itself  . What would cause this?
Use the search function here in the forum and you will find the detailed answer
Short answer (if I remember correctly): If the Pylon is only used as backup and is in standby (not charged/discharged) for a certain period of time, it produces that error message
