Harry Khiani Posted September 27, 2020 Share Posted September 27, 2020 My current setup I have 16 430w Canadian solar on one pv and the next pv is 255w 20 panels. I have enough generation . I have a deye 8k inverter what I have been noticing is that inspire of it being a bright sunny day when I switch on loads it takes from pv and grid. When I truly know that thevpv can support the full load . Attaching some images Quote Link to comment Share on other sites More sharing options...
gbyleveldt Posted September 27, 2020 Share Posted September 27, 2020 That’s a LOT of PV panels. With only 16*405w panels I routinely generate around 5.7kWh when the batteries are charging. Today I generated 35kWh; I don’t know your Deye model, but I was under the impression those blend power? Quote Link to comment Share on other sites More sharing options...
Rob83 Posted June 29, 2021 Share Posted June 29, 2021 Hi..experiencing same issue but with 2 x 5kW Deye in parallel. Did you manage to resolve problem? Quote Link to comment Share on other sites More sharing options...
