September 28, 20205 yr I have an Axpert 1kV/24V. The cooling fans are mounted below the heatsinks and blow downwards. I find this unusual as I would have expected the fans to blow "fresh" air UP into the heatsinks. Why would Axpert/Voltronics have done this?
September 29, 20205 yr 18 hours ago, Adri said: Why would Axpert/Voltronics have done this? This question has been asked many times - and no one has a good answer... (see fan section of this thread for more details) Changing the direction of the fans results in a significant improvement in temperature. I've just had this done on my Axperts and I changed from temps in the high 40's with external fans stuck to the chassis to temps in the mid 30's without any external fans
