PV Out
Maybe i am missing the bus, but i don't understand. The V3 (Energy Consumption) must always be positive. With the Axpert this works fine as the panels slow down if the battery's are full.
Now with the Infini that panels produce at max. How do i export the value to v3 if the total grid use is -1.9 Kwh?
Thanks Mark No it can only take positive values. I played around on pvout and figured it out with Cobus
Pleasure Kobus. Wish mine can just look half that good
Time to get the Infini
Install the Infini Manie, that makes all the difference [emoji3]
Very true. All goes well month end [emoji1]
For me this application by Manie is basically all an Infini owner needs. It can communicate with the Infini and then uploads the data live to emoncms and pvoutput. Emoncms more for live monitoring, high frequency/short time window. PVOutput is for longer term trends and data storage.
The Infini does not need to be watched and managed. My batteries are always on float (unless we have a power failure obviously), I check for error messages once a week (haven't had any yet) and the rest of the time it just works.
Really pleased with the Infini, and Manie has solved the only shortcoming for me, updating to the cloud.
Thanks again Manie, I owe you big time.
Pleasure. You can help me with setting on the infini. 😆
Now to get the 5kw working as well.
Just some small changes then it will work on the 5kw
  • 5 weeks later...
What software are you using to do this?
Jaco is testing the 5kw. The one on the video is for the 5kw. Cobus is testing the 3kw and me the Axpert
