  • 0
Mr B Basel
Bernard basel
 Share
Question
2 answers to this question
  • 0
22 hours ago, Bernard basel said:
1200 Inverter 7500 w please advise which amp I must set it on     10amp  or   20amp
A few more details, please. Is it a 1200 W inverter? What does the 7500 W refer to? PV power? That seems a lot in comparison to the inverter power.
What type battery do you have? If possible, post the model number.
  • 0
Based on the criptic description I'm assuming that it is the Mecer 1200VA 720W inverters as they normally have a switch at the back to select either 10a or 20a charging.
This would depent on the battery specification and cable sizing.  Please advise which battery you are using and what cable size.  I would however suggest to stick with the 10a charging if the inverter is purely used as load shedding backup.
Answer this question...
 Share
