November 29, 20205 yr Hi all I have an issue with RCT 5Kva (Axpert)all 3 lights flashing every half second with clicking sound(relay) battery voltage 51v using only as UPS no solar connected input voltage normal but no output voltage, any help would be appreciated Regards Rob
November 29, 20205 yr 5 hours ago, Rob Firefly said: Hi all I have an issue with RCT 5Kva (Axpert)all 3 lights flashing every half second with clicking sound(relay) battery voltage 51v using only as UPS no solar connected input voltage normal but no output voltage, any help would be appreciated If the battery connection is good (check at inverter terminals with a multimeter), then it sounds like a faulty internal power supply.
