December 27, 20205 yr 22 minutes ago, Achmat said: Do you have a screen similar to this one. Ignore the previous pictures.
December 28, 20205 yr So the final solution. Het Deye support, upgrade the software and Bob’s you’re uncle😁
December 28, 20205 yr 3 hours ago, KobusK said: So the final solution. Het Deye support, upgrade the software and Bob’s you’re uncle😁 Fixed?
May 30, 20224 yr On 2020/12/28 at 4:36 PM, KobusK said: Yes works like a dream 👍👍 Hi Kobus, how did you update it?
June 3, 20224 yr On 2022/05/30 at 11:04 PM, Davy9 said: Hi Kobus, how did you update it? If you have it connected to the internet via your wifi then you can email Deye support with your serial number and request a firmware upgrade.
