February 8, 20215 yr Hi guys If I call the Axpert Max with the QPIGS command, the PV watts is the same as the inverter screen displays for MPPT 1 and is not the total MPPT. Does anyone know how to find the value of MPPT 2?
February 9, 20215 yr 5 hours ago, Denarius said: Does anyone know how to find the value of MPPT 2? Try QPIGS2. Look it up in a recent protocol manual. I believe that there is one on this forum. Edit: It looks like the MAX has a different QPIGS2 response data format (clever 🙄 And QPI still returns PI30). Looks like there are only 3 fields: PV2 current, PV2 voltage (values less than 60.0 V display as zero), and PV2 power. Edit 2: That's with firmware version 90.11 (50.00 for the 120 V version). I expect the earlier firmwares to be the same, but haven't checked. Edited February 9, 20215 yr by Coulomb
February 9, 20215 yr Author Thank you @coulomb, that was exactly what I was looking for. Your knowledge of the internals of these inverters is amazing. (09.4 128.7 01213 I guess if you have multiple Axpert Max in parallel, you can only read the MPPT2 of inverter you are connected to. Edited February 9, 20215 yr by Denarius grammar
February 28, 20215 yr Author On 2021/02/09 at 2:05 PM, Denarius said: I guess if you have multiple Axpert Max in parallel, you can only read the MPPT2 of inverter you are connected to. @coulomb Is this the case? Is there no way to read MPPT2 of the inverters not connected directly via USB?
March 1, 20215 yr On 2021/03/01 at 12:01 AM, Denarius said: @coulomb Is this the case? Is there no way to read MPPT2 of the inverters not connected directly via USB? Oh. Yes, it looks that way. Seems quite an oversight. Other models appear to have a QP2GSn command, for reading the PV parameters for machine n. Or at least, that's what is documented in the protocol manual. Maybe only the older dual- and triple- MPPT models implement this command. Edited March 1, 20215 yr by Coulomb Removed last sentence, which in retrospect was irrelevant.
