Soft/Hard/Easy starter.
Tokkiebod
 Share
Who used one of these starters on their fridges / aircons?
Did it work?
Where can I buy one?
The reason why I asked , i want to use it on my fridges to reduce the inrush current during the night. My 4 fridges kicks in at the same time during the night, which trickers my inverter  to change over to utilitiy, which increases my bill.
Using a soft starter will mean replacing the entire air-con or fridge unit. The entire air-con needs to be replaced with a inverter drive air-con. They use at least 40% less power then the normal air-cons. It is in some cases worth replacing all the air-con units within a house with inverter drive air-cons to reduce the required inverter capacity when going solar.
Gerrie is correct.
Standalone soft starters and Variable speed variable frequency drives are for 3 phase induction motors.
Unless you have a pretty big fridge or aircon it won't have a three phase motor 🙂
If don't already have A+ appliances have a look they generally pay for themselves in the long run.
Modern appliances come inverter supplied motors.  That will have a reduced startup current. But it probably won't be feasible to retrofit to an existing appliance.
As a cheap fix you could have them all on their own timers. Staggering their running times.
A fridge that stays closed won't lose that much during the night
Edited by Jaws
 Share
