June 12, 20215 yr Hi Folks, I cant seem to find these panels anywhere. I currently have x12 already running x6 each off its own MPPT string using a GoodWe 5048ES Hybrid inverter. I want to now upgrade each string to x9 panels each which is my max. Ive been told I cant mix and match but also been told I can providing Voc is the same and the Voc on my panels are 45.8V. See picture attached. Any suggestions on what panels I can try get or unless anyone knows who has stock of Canadian Solar Panels Model CS6U-335P ?
June 12, 20215 yr @Jaybabe, I have the exact situation as you, I am going to use Canadian Solar 360 watt panels, you can use any size larger than what you have, in series the wattage is reduced to 355 watts.
