Doron Posted June 26, 2021 Share Posted June 26, 2021 Hi all. I recently upgraded from my axpert 5kw to the new axpert / synapse 7.2+. ive connected the WiFi module that comes build into the 7.2. my question is how to get WatchPower app or different to send me a email when power changes etc. before I used a laptop and usb permanently connected with WatchPower program running … however these inverters have built in WiFi but I don’t see any place to configure … is there other software I could Connect Quote Link to comment Share on other sites More sharing options...
Doron Posted June 27, 2021 Author Share Posted June 27, 2021 Hi thank you for the feedback. I’ll try the as per your suggestion thanks Quote Link to comment Share on other sites More sharing options...
Doron Posted June 28, 2021 Author Share Posted June 28, 2021 Hi Guys, does any body know if either solar assist or icc do email notifications... I downloaded solar assist and installed nice and easily to my raspberry pi, however nowhere am I able to get notifications when line fails for example... hence I still use a old laptop and watchtower for that. would be great to just use the rasberry pi. thanks Quote Link to comment Share on other sites More sharing options...
Doron Posted June 29, 2021 Author Share Posted June 29, 2021 Hi, yes it works great I must admit.. just the email alerts would be a great addition indeed. maybe somebody could assist with development. it shouldn't be too difficult as its cloud based anyway. Quote Link to comment Share on other sites More sharing options...
Shadders Posted June 29, 2021 Share Posted June 29, 2021 Solar assistant now having MQTT allows you to interface with Home Assistant / Node Red or other automation software that can handle MQTT if you have this already running. Otherwise a quick web search led me to this which also seems viable, especially if @Doron, you have an old pc lying around already. https://openautomationsoftware.com/knowledge-base/mqttt-alarm-notification/ Quote Link to comment Share on other sites More sharing options...
Shadders Posted June 29, 2021 Share Posted June 29, 2021 17 hours ago, Doron said: Hi Guys, does any body know if either solar assist or icc do email notifications Just to add that ICC does support email notifications but this is limited to errors and as far as I know there is no way to define utility loss as an error. ICC does have MQTT integration and you can install Node Red or other automation software alongside it unlike SA so you can use one pi to do everything if you like. Quote Link to comment Share on other sites More sharing options...
Shadders Posted June 30, 2021 Share Posted June 30, 2021 23 hours ago, Shadders said: ICC does support email notifications but this is limited to errors and as far as I know there is no way to define utility loss as an error. Correction. utility loss is defined as an error and triggers an email as I discovered this morning. There was a bug in the older version of ICC that stopped the mail notifications from working but this has been fixed in a recent update. Quote Link to comment Share on other sites More sharing options...
