July 10, 20215 yr Regarding electronic devices, in terms of calculating how many watts a device draws, say a WiFi modem, does one calculate the input or the output on the dc converter? the specs are as follows input 240v 0.8amps (192watts) output 12v 2 amps ( 24 watts) there seems to be quite a big wattage difference
July 11, 20215 yr 15 hours ago, sunset1 said: input 240v 0.8amps (192watts) output 12v 2 amps ( 24 watts) there seems to be quite a big wattage difference Typically, input specifications are for the peak power ever seen, so you can design the power supply to cater for that need. A power supply often has a turn-on surge that lasts less than a second; that would be where the 192 watts comes from. The power supply's output rating is generally a continuous rating; it should be able to supply 12 V at 2 A all day. So IF the load was at maximum, that's 24 W as you say, so most of the time the input power would be about 10% more than that, say 26 W, with a brief excursion to a maximum of 192 W at switch-on.
July 11, 20215 yr Author 1 hour ago, Coulomb said: Typically, input specifications are for the peak power ever seen, so you can design the power supply to cater for that need. A power supply often has a turn-on surge that lasts less than a second; that would be where the 192 watts comes from. The power supply's output rating is generally a continuous rating; it should be able to supply 12 V at 2 A all day. So IF the load was at maximum, that's 24 W as you say, so most of the time the input power would be about 10% more than that, say 26 W, with a brief excursion to a maximum of 192 W at switch-on. AH ok thanks for the explanation! I thought maybe the adapter was just burning the difference (192 watts - 24 watts) in stepping down the watts and was thinking, that sure is a waste of x amount of watts lol. thanks for the help again.
July 13, 20215 yr On 2021/07/12 at 12:01 AM, sunset1 said: I thought maybe the adapter was just burning the difference (192 watts - 24 watts) If it was, it would be getting burning hot! 🔥
