RCT 8k max inverter
There is no RS232 port on the inverter or on my laptop. Can you link from the watchpower program on the laptop to the inverter via wifi? I am trying to find what version of firmware i am running. Thank you
What I notice on the max, is that it always seems to have the bypass arrow shown, even when you set it to SBU (battery full), the bypass disappears for a short time (sometimes), and then returns.
Even on manual timer setting, the bypass is always shown?. I was thinking there is a newer firmware update?
Thank you for all your input. I have the software on the cell. It shows 2 firmwares. Is this the latest? I do have the 69 warning, i just ignore. I just don't know why the bypass shows when i know i have enough solar and battery to cover the load when set on SBU.
I am planning to put my 200l geyser onto the system via a timer set between 12 and 16.00.via a change over switch back to eskom when load shedding.... And may be change element from 3kw to a 2kw.
Made up a bms comm cable.. And pylontechs communication is successfully working, besides the #69 warning. Do you know if there is a later firmware version.
Thank you for your advice
Re back to discharge voltage... Do i have to decrease this number so it uses the battery in SUB mode and not jump to bypass mode?
There will be, hidden as an RJ-45 connector (looks like an ethernet port). It's the port on the end with the screen and keyboard icon.
The inverter should have come with a cable that adapts this to a standard D9 connector. You can use this with a USB to RS-232 adapter.
But WiFi and/or Bluetooth should also be available. The phone app is (or was) missing a few details, such as removable display firmware version.
