Going off grid
Hi my name is Kevin. I need advise on a installation with 2  X 5kva Sunsynk inverters I have installed one on each phase and have the CTs on each phase at the meter box. The CT reading at this stage with very little load are 0 and as soon as I turn on the PV isolator it goes into negative numbers. Is it possible running back through the neutrals . Also what does the CT ratio need to be set at.
Please advise
Kevin Levin
Please advise
Kevin Levin
Could you perhaps attch a few pictures of your wiring, db board etc.... it is quite uncommon to see a house with a two phase install.
That sounds like the CT’s are installed the wrong way, In the manual there is mention of negative Watt readings if coils are wrong way.
My 5KW ct ratio did not need to be set, it worked first time without setting.
