September 27, 20214 yr 👋 Hello everyone In Axpert off-grid inverters When we select SBU in And on number 16 choice select SOS And AC power connect to inverter Bypass will not work coz there PV and battery.... If PV not enough to load the inverter will take from battery If battery become empty or as 12-13 choices The bypass will work Q: Can merge Utility with PV without bypass...... And can use the inverter to stabilize the AC power....      Â
September 27, 20214 yr 2 hours ago, Abo Noor said: Q: Can merge Utility with PV without bypass...... And can use the inverter to stabilize the AC power.... You didn't say what model of Axpert inverter you have. As far as I know, only the Axpert King can stabilise AC voltage, as it has dual conversion when in Line mode (different from Bypass mode for that model). It converts AC-in to DC, and back to AC again, where the voltage will be constant except for an occasional minor glitch as the load or AC-in suddenly changes. My understanding is that of the other models, only those with the higher voltage Solar Charge Controller (PV max voltage is 450V or 500V) can blend AC-in and PV power, and only when in SBU output source priority (setting 01). It sounds like you have a low voltage SCC model like mine (145V max PV) , so you can't blend. For me, that's little hardship, as I have a medium sized battery and load shedding is extremely rare. For South Africans, that may be more of an issue. Edited September 27, 20214 yr by Coulomb
September 28, 20214 yr As Coulomb said there are a few axpert type hybrids most are high voltage. I have attached a picture from a manual from mine which is a growatt spf5000es. What model do you have?
September 28, 20214 yr Author Thanks for your replay In our place there co. MOD all offgraid inverters to be Hybrid He say put circuit for that... And the inverter will stabiliz the AC power So i ask.... So i think the Mod by software not by Circuit....
September 29, 20214 yr 13 hours ago, Abo Noor said: And the inverter will stabiliz the AC power I suppose that a true grid interactive inverter (even an Expert in SUB mode), which puts the inverter in parallel with the utility, should improve the utility waveform to some degree: pushing the voltage up if it's low, rounding out the peaks that tend to get flattened by cheap power supplies. But unless the connection to the transformer is poor, or the inverter is very powerful, the improvements would be very modest, I would think.
October 1, 20214 yr Author Yesterday i connect AC to diode bridge after that soldering to inverter capacitor I was 100% But not get any wattage even battery down This without connect AC to Inverter as Utility But when connect AC to Inverter This idea not pass coz inverter bypass So are there way to stop bypass If stop bypass inverter will take wattage from alternative AC .... Or i have idea We want Bypass command to RUN alternative AC... But should stop bypass logo in LCD and interrupt stop inverting to Bypass .....    Â
October 1, 20214 yr Author Other matter are there Source code for Axpert And wiring diagram to know command lines... Thank's Â
October 1, 20214 yr 4 hours ago, Abo Noor said: Yesterday i connect AC to diode bridge after that soldering to inverter capacitor Yikes. That sounds dangerous. By "inverter capacitor" do you mean the bus capacitors (2 x 470 μF ~450 V)? What were you hoping to achieve by this? Quote So are there way to stop bypass Yes, appropriate output source priority, battery voltage, and settings 12 and 13 (back to utility and back to battery voltages respectively). Quote We want Bypass command to RUN alternative AC... I don't understand this.
October 1, 20214 yr 4 hours ago, Abo Noor said: are there Source code for Axpert I've never seen source code for any Voltronic Power firmware. I have small parts of various firmwares disassembled, but that's a long way from source code. 4 hours ago, Abo Noor said: And wiring diagram to know command lines... A bit over half of the commands are documented in various protocol manuals; a bit more in later protocol documents. Check the file section of this forum, and the AEVA forum.
October 3, 20214 yr Author The proplem When select SBU output power Will take power from PV if not sufficient will take from battery at the same time But if battery drop to setting point on program 12 Will start bypass "this my proplem" I have connect AC to Bridge after that to 450V capacitor If inverter go to bypass will not take any power from my new connection Note I test this way without utility power It work 100% Inverter if battery drop will give error code but take power from new connection 100% Finally Can we make patch or way to make SB output power way without utility Fir if battery drop inverter will take power from new connection ...... Thanks for replying Â
October 3, 20214 yr 12 hours ago, Abo Noor said: Will start bypass "this my proplem" I have connect AC to Bridge after that to 450V capacitor If inverter go to bypass will not take any power from my new connection 230 VAC rectified comes to about 325 VDC. The bus voltage is usually around 360-400 V, to allow for several volt drops across the IGBTs and still be able to generate a 230V sine wave. So the diodes in the bridge will always be reverse biased. That's why the inverter won't draw power from that source. When the inverter goes to bypass, it energises relays that connect AC-out to AC-in. It sounds like you have nothing connected to AC-in. You still haven't said why you want to use this diode bridge connected to the DC bus capacitors. It still sounds horribly dangerous to me, and I worry about neutral current flowing to bad places. I also wonder what will happen if the firmware tries to charge from utility. But perhaps you have a valid reason to do this.Â
