Hi, any recommendations in terms of the physical size of PV panels? I see the 540W JA Solar units are 2279mm x 1134mm × 35mm and a colleague commented that installers don't favour these due to the physical size and it being difficult to handle for two people. With the efficiency seeming to improve with size I guess the 'difficult' installation can be seen as a once off hassle?
they're very bulky and heavy for one person to handle, mine were 465w however.
2 people makes it much easier.
in my case I have a landrover with a heavy duty 4x4 roof rack which can handle a lot of weight safely, and simply got my supplier to load onto the roof. (only a 15 min drive back)
back home, line up with the carport and instant roof level panel unloading, no mess no fuss.
having done it as 1 person, I can really say its not for the faint hearted, rather get a friend in.
Approximately 2279mm x 1134mm × 35mm is pretty much the industrial size used in ZA.
If you have the space, then it's not a problem.
Does required 2 people to handle and correct mounting on the correct clamping zones to prevent flex and damage.
