January 21, 20224 yr I had a request to make a temp. setup for a customer. the one was for an office and the other to connect tot the garage sub DB. I have another request, this time to install a Sunsynk 5.5 KVa hybrid with a 5.2 kwh lithium battery. I was thinking Hubble with the riot, but now thinking rather a BSL with solar assistant. I thinking about doing a similar setup, mounted on a board so that the entire system can be pre wired, mounted and programmed in my workshop. I will be adding fuses and lightning protection for panels and a Pi3B+ to connect solar assistant. Then taken to site and installed as one unit.
January 21, 20224 yr Have seen some posters doing it on Youtube, it is a good idea, will save time at the site, depends on space at the clients site though
