February 11, 20224 yr On my Axpert RCT - AXMAX8k, I upgraded main cpu firmware from version 46.02 to 46.05 and remote panel firmware from 12.03 to 12.06. System now running as it should..... using solar more efficiently, approx 40% more solar generated on demand ( before it stayed on bypass most of the time and blended power) now stays on battery mode for most of the day when solar output is higher than usage.
February 13, 20224 yr Hi Kieftus. I have just installed a pair of RCT Axpert Max 8kW units, operating in parallel. They replaced a pair of old 4kW 5000VA Axperts. I'm getting lower solar yields from the new units, despite rewiring my panels to take advantage of the higher voltage MPPTs. Is this a known issue? Can you send me a link to the new firmware files please?
April 3, 20224 yr Author my email to you bounces back... 2 separate emails with a zipped file attached on each
April 4, 20224 yr 11 hours ago, Kieftus said: my email to you bounces back... If Gmail is involved, they will find the executable inside and refuse to send it. You could upload it to this Google Drive folder; then I get a copy too 🙂 https://drive.google.com/drive/folders/1L2Ohl72qmn-hNDrQh79m6JTAKAqC7Bu1?usp=sharing
