Raw access to Growatt Inverter Data
  • Replies 94
  • Views 54.9k
  • A couple of weeks on, and I'm reporting on my findings to date.  There appear to be three options 1. query locally via direct cable - reports of the software for this as sketchy at best. 2.
  • Antonio de Sa
    Antonio de Sa
    Herewith dashboard of my two Growatt custom made monitoring system for this month, as @zsde explains there is a slight discrepancy in the measurements maybe due to calibration and small losses, in my
  • Hello from Australia, This thread has been very useful, so I thought I would share something i just discovered.  I have also had the issues with exporting data from the growatt web page, and I
Hurrah - glad to help!
Main issues were therefore around permissions / paths in Linux rather than the script itself.
Do bear in mind that /tmp (as a temporary directory) gets wiped each time the server restarts.
Enjoy
Mike - I got another permissions error so I went back and set the Tmp folder permissions with
sudo chmod -R 777 /tmp/
via terminal.
When I run the file with or without Sudo it gives the following error
python3 ./processToFiles_light.py
dayToProcess is: 2022-05-04
Traceback (most recent call last):
  File "/home/Growatt/Script/./processToFiles_light.py", line 90, in <module>
    chartData = mix_detail['chartData']
TypeError: 'NoneType' object is not subscriptable
Edited by L_D
Enjoy
Hi Mike - I created a AWS Linux AMI and I am MUCH closer.
[ec2-user@ip-172-31-20-164 Growatt]$ python3 processToFiles.py
dayToProcess is: 2022-05-08
  File "processToFiles.py", line 38, in <module>
    user_id        = login_response['user']['id']
KeyError: 'user'
I checked, the username pwd combo is correct and able to login via web browser, above error seems like it is kicking me out becasue of a bad username?
I get the same error using these example python scripts where you have to enter your username and password.
Browser login URL is: https://server.growatt.com/login
user_name = "ldusername" # add server login here
user_pass = "LDpassword" # add server password here
Edited by L_D
I don’t believe running as sudo is actually needed hence worth removing that.  Keen to understand steps that 0xEF did to get working.
I’m unsure from here.  Clearly the username / password combo via the scripts should work as well as per the API.
I have found that the app has been a bit hit and miss today - with timeouts. Perhaps retrying the API at another time??
You are right Mike, the login is somewhat unstable.
This morning it managed to get past the login and then gave this error:- any ideas as to why?
During handling of the above exception, another exception occurred:
  File "./GW.py", line 22, in <module>
    login_response = api.login(username, user_pass)
  File "/home/ec2-user/.local/lib/python3.7/site-packages/growattServer/__init__.py", line 59, in login
    'password': password_md5
  File "/home/ec2-user/.local/lib/python3.7/site-packages/requests/sessions.py", line 577, in post
    return self.request('POST', url, data=data, json=json, **kwargs)
  File "/home/ec2-user/.local/lib/python3.7/site-packages/requests/sessions.py", line 529, in request
    resp = self.send(prep, **send_kwargs)
  File "/home/ec2-user/.local/lib/python3.7/site-packages/requests/sessions.py", line 645, in send
    r = adapter.send(request, **kwargs)
  File "/home/ec2-user/.local/lib/python3.7/site-packages/requests/adapters.py", line 517, in send
    raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='server.growatt.com', port=443): Max retries exceeded with url: /LoginAPI.do (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1091)')))
Edited by L_D
Many thanks Mike for sharing your script, it was almost exactly what I was looking for. It was all working fine, as was another script I wrote, until the other day and now it seems to error on the login part. Is anyone else having these issues?
Yes. It’s the same via the app though. Logins (mainly timeouts I feel) are a problem. There are definitely times in the day when it’s more common to have timeouts.
perhaps there is a timeout configuration for the api client (and / or some error handling) that can be added.  I’ve not checked
OK thanks - I will do some digging too.
Just an update on this, it kept happening until I stumbled on another thread advising to update the login in growattServer/init.py to "newTwoLoginApi.do" rather than "newLoginAPI.do". Seems they changed this in the latest update.
hi, i also get this response (as normal user or with sudo):
dayToProcess is: 2022-09-04
  File "processToFiles.py", line 91, in <module>
    ppvToday_dayAPI = mix_detail_day['chartData']['ppv'][DayOfMonth_i]
the /tmp/-folder-solution did not work. any other ideas on how to fix this? there are a few json-files created, but in none of them is the required data (e.g. the content of the file growatt-mix_detail-2022-09-04.json is "null"..?)
  • 4 months later...
Hi,
To those who concerned, for the growatt grid tied inverter you can get the access to the data at
"https://server.growatt.com/plant.do"
Login with the credentials.
In the page, click on "Device List" tab then on "MIN/MIC/MOD/NEO", which shows a table of devices connected. Double click on the device you wish to query the data, a pop window appears with history. There is search button and export button.
Export will give the excel tabulated data for the current day. In the search tab you can download the data for any day, I could go upto 4 months of data at max. At a time you can download data for 4 days in a single excel, though the website says maximum 7 days it prints "Too large file" if you select more than 4 or 5 days at a time.
Attaching the screenshots for the reference.
Regards,
antarya
Edited by antarya
Hi,
I have just bought Growatt inverter and would like to extract data from growatt server and send it to PVOutput.Org as i have data there for my 2 inverters for 10 years, but one inverter failed  recently, and i got a new Growatt. I would like to transfer data to the PVOutput to be able to compare my invertes ect.
I have tried to run the script ProcessToFile.py. I have none to little experience with Python and have no experience setting up api calls.  I have installed python 3.11 on windows. I have included the module : growattServer but when i tried to run the script it gave me a login error.
I cannot figure out if i have miss something in the script setup ?.  plants Id, api key, inverter name or it is a commen error in the login setup.  I have only changed 2 lines in the script :user_name  and user_pass  has i changed to my credentials i use to login on http://server-api.growatt.com/login
Here are the output when i run the script.
Python 3.11.2 (tags/v3.11.2:878ead1, Feb  7 2023, 16:38:35) [MSC v.1934 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license()" for more information.
= RESTART: C:\Users\ottos\AppData\Local\Programs\Python\Python311\processToFiles.py
dayToProcess is: 2023-02-11
  File "C:\Users\ottos\AppData\Local\Programs\Python\Python311\processToFiles.py", line 37, in <module>
    login_response = api.login(user_name, user_pass)
  File "C:\Users\ottos\AppData\Local\Programs\Python\Python311\Lib\site-packages\growattServer\__init__.py", line 131, in login
    response = self.session.post(self.get_url('newTwoLoginAPI.do'), data={
  File "C:\Users\ottos\AppData\Local\Programs\Python\Python311\Lib\site-packages\requests\sessions.py", line 635, in post
    return self.request("POST", url, data=data, json=json, **kwargs)
  File "C:\Users\ottos\AppData\Local\Programs\Python\Python311\Lib\site-packages\requests\sessions.py", line 587, in request
  File "C:\Users\ottos\AppData\Local\Programs\Python\Python311\Lib\site-packages\requests\sessions.py", line 708, in send
    r = dispatch_hook("response", hooks, r, **kwargs)
  File "C:\Users\ottos\AppData\Local\Programs\Python\Python311\Lib\site-packages\requests\hooks.py", line 30, in dispatch_hook
    _hook_data = hook(hook_data, **kwargs)
  File "C:\Users\ottos\AppData\Local\Programs\Python\Python311\Lib\site-packages\growattServer\__init__.py", line 41, in <lambda>
    'response': lambda response, *args, **kwargs: response.raise_for_status()
  File "C:\Users\ottos\AppData\Local\Programs\Python\Python311\Lib\site-packages\requests\models.py", line 1021, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: https://server-api.growatt.com/newTwoLoginAPI.do
The result in VS2019
Kind Regards,
Otto Sembach
On 2023/02/09 at 11:03 PM, L_D said:
@antarya, once logged in I dont have the "Device List" option.
See screensnip below:
Ah! I see the problem. So the Growatt maintains two types of interfaces both has similar name. I am not sure how it is done but if you go directly to
https://server.growatt.com it takes you to the above interface but instead, goto
https://server.growatt.com/login.do   URL has to be https:// not http://
It takes you to the interface I have posted in my previous posts. I suggest clearing cookies or opening in "Private Window" to avoid your
browser from reloading using previously stored cookies.
Let me know if you could get the access.
Edited by antarya
On 2023/02/11 at 9:17 PM, OttoS said:
Hi,
Kind Regards,
Otto Sembach
Hi,
I have not got into the code part yet but generally for the api access you need API key from the vendor.
If there's any other way to get the data using the code I'll try to figure it out and post it.
In the meantime, you can download the data from here
Check my posts above for more details.
In the web, you can't access data beyond 60-90 days depending on the model so get the data downloaded soon.
Edited by antarya
On 2022/05/01 at 10:32 PM, Mike_C said:
My overdue update of #3.  I have found it to be stable enough / gives me what I want that I have not explored option #2 at all.
I have found that growattServer 1.2.0 to be the best for my needs.
It can be installed via:
pip install growattServer
Details can be found here: https://pypi.org/project/growattServer
I have no affiliation to this project; I am just one customer / user that has found it to give me what I need.
I have this running on an m1 mac and have attached my python3 script.  I can't comment on how easier it is to translate this to windows / linux (if any 'translation' is needed at all).  Either way, before running, complete the set up variables configuration (line 11 to 15).
To run (based on today’s date) :
python3 ./processToFiles.py
To run (based on YYYY-MM-DD) provide three separate parameters :
python3 ./processToFiles.py YYYY MM DD
The files generated are a combination of direct API call output and some calculated values.
A summary csv is generated detailing (and this is how I think about energy created / used):
  • Solar (PV) to battery (i.e. stored)
  • Solar (PV) to user (i.e. used at time of generation)
  • Solar (PV) to grid (i.e. exported)
  • Battery to user (i.e. used post generation)
  • Grid to battery (should be close to zero but fluctuates)
  • Grid to User (imported energy)
I then compare this CSV in Excel to that provided by my energy provider - i.e. exported and imported values.
Mike,
What was the API key? Did you get it from the Growatt by writing to them or is it available anywhere in public fourm?
Edited by antarya
Hi,
Kind Regards,
Otto Sembach
Their API guide says to write to them for API access.
https://growatt.pl/wp-content/uploads/2020/01/Growatt-Server-API-Guide.pdf
I suppose one can try that
1 hour ago, antarya said:
Try this URL instead
Thank you, that did the trick to get to the URL
Edited by zsde
