February 26, 20224 yr Has anyone used the Goodwe LAN module ? We have a site with frequent problems with poor wifi signal. The wifi repeater improves it marginally but wifi drops still too often. GoodWe GW-LAN-Module - Sinetech (sinetechstore.co.za)
February 27, 20224 yr Before you shell out, check that the firmware for the wi-fi module is up to date. This is separate firmware from the rest of the inverter functions. When my Goodwe was installed there were lots of problems with the wifi. The firmware was upgraded and now it is rock solid.
