March 8, 20224 yr Has anyone else noticed that since the last updates/maintenance which Solarman has made on their apps/platforms/websites, that they seem to have dropped the "temperature" monitoring from their charts?
March 24, 20224 yr On 2022/03/08 at 12:25 PM, RabidBunny said: Has anyone else noticed that since the last updates/maintenance which Solarman has made on their apps/platforms/websites, that they seem to have dropped the "temperature" monitoring from their charts? Yes, i have also noticed this on my instance
May 1, 20224 yr Author On 2022/03/14 at 10:40 PM, Deeos said: No not on the bms connection I'm referring to the History/Charts section, you cannot select any temperature parameters for that matter anymore. It shows the current BMS, DC and AC temperatures, but one can't track the temperatures on the charts like you used to. The same is true for the Inverter temperatures, I used this to try and determine if the "fan" I installed made a difference (in cooling down the Inverters), but now it's hard to see the graphs.
