Sunsynk backup settings?
Hi all,
Is there a way to get the inverter to keep my batteries charged 100% without needing to adjust the SOC settings in the system mode screens?
For example, I typically let my battery discharge to 30% overnight until 7am, then let the grid charge it to 40% until 9am and then let the panels do their thing until 17:30.
That works well for me on a normal day, even stage 2 loadshedding, but today being stage 4 and raining I need to quickly get my batteries charged to 100% from the grid before loadshedding kicks in at 9 and the only way I could figure out was to change the SOC settings to 100% on the system mode 1 screen for this time window.
Is there any other way to do this without messing with my timer settings?
I had hoped unticking use timer and unticking priority load would work, but that didnt.
Grid charge is ticked on my battery settings page.
un-ticking use timer should set the inverter to only use battery when there is no grid, not sure that un-ticking priority should have an effect on use timer though
