Deyan Vitanov Posted April 17, 2022 Posted April 17, 2022 So as I spent a lot of money for my Pylontech US3000C batteries, I was thinking: is it possible to find a Pylontech BMS and connect it DIY LiFePO4 cells with the idea to expand my storage at low cost? I have some new LiFePO4 chinese cells that I want to hook up. I could not find any Pylontech BMS board over the internet. I guess this is possible if I set my Growatt inverters to US2 battery mode (custom charge/discharge mode) but I really want to keep the communication between the Pylontech BMS's and my Growatt inverters. I believe this is the future as individual cells always well be way cheaper than pre-build modules and in 3-4 years we will have plenty of cheap options to upgrade our high cost existing systems. Thanks Bamba 1 Quote
CopperEagle Posted June 21, 2022 Posted June 21, 2022 If you don't mind me asking, how did you get the cells? Quote
P1000 Posted June 22, 2022 Posted June 22, 2022 On 2022/04/17 at 10:54 PM, Deyan Vitanov said: as individual cells always well be way cheaper than pre-build modules I find that dubious - unless you import a lot of them. And in that case it is cheaper to import complete batteries. You won't find a Pylontech BMS... Quote
P1000 Posted June 22, 2022 Posted June 22, 2022 10 minutes ago, stok said: agree, the pylontech bms is a elusive creation, pylontech cells on the other hand...I have a couple 25ah pylontech pouch cells lying around. weird thing is pylontech batteries is rated at .5c discharge rate, these cells are rated at 3c? 6000 cycles at 100%DOD 0.8c rate with 80% remaining. I've always been of the opinion that the Pylontech .5c rate is for longevity. Nexuss 1 Quote
