June 24, 20224 yr Just a relative nooby question. Have been watching SA this morning whilst charging up the batteies before LS at 2pm today and noticed the following: When there is PV available, the batteries charge at a high wattage and just about match what the PV is generating. When PV drops away due to cloud cover, Grid then kicks in but the batteries charge at a much lower wattage. Jusy curious as to why the difference? Because of DC on PV and AC on Grid? MdF Edited June 24, 20224 yr by MdF
June 24, 20224 yr Author Jacques, of course you are correct with you answer (note to self: insert facepalm emoji here). Thanks. MdF
June 24, 20224 yr 5 hours ago, Jacques Ester said: Your grid charge rate is set low. You've just solved a problem I didn't realize I had! My charging rate seems to be governed in some way and now i know why!!
June 25, 20224 yr On 2022/06/24 at 8:27 PM, MdF said: Just curious as to why the difference? Because of DC on PV and AC on Grid? The two charge sources (PC and AC) charge the battery through very different pathways, and there are different limits on these pathways.
