GoodWe GW5048D-ES with DIY battery pack and BMS with RS485 or CAN communication
HELLO!
Let me start by saying ze this is my first topic on the forum :)
I would like to ask the forum community if anyone has tried to communicate a GoodWe GW5048D-ES inverter with an external BMS for a homemade battery pack. I have not found anywhere information about the communication protocol that is used in the inverter. I have a problem with this topic and decided to ask myself if anyone has already come up with such an idea.
Thank you in advance.
Greetings!
Edited by mark00
12 hours ago, mark00 said:
HELLO!
Greetings!
Depends on what your BMS/Batteries want. There is a "default lithium" setting available on the Goodwe, but you can't manipulate the parameters using the app. If your pack can live with those settings (and if you can make up the right cable), then you're away.
Or if you want to run without comms you can use the "self define" mode. Which does allow you to edit the various parameters, but will ignore comms with the BMS.
