Felicitysolar batteries
On 2022/08/18 at 11:59 AM, TiaanSmit said:
I seriously considered this battery but ended up buying a custom built navitas battery instead. Ended up getting 15.36kWh of battery capacity for much less of that of 2 x felicity batteries.
Hi there. Could you tell me where you got your custom batteries from and how good they are as I was planning on buying 3 of these batteries.
Hi there, I bought them from Navitas energy in Stellenbosch
078 443 5272
Absolutely no issues after 6.5 months of use.
On 2023/04/16 at 9:16 AM, Millmatt said:
Does the same custom cable work with a growatt inverter. 5 and 6 to 1 and 2 pin?
Growatt with Felicity battery
Network cable: pins 1 and 2 from the inverter side to be connected to 5 and 6 at battery side.
Select Li battery at parameter 05 and set the parameter 36 (protocol) to 04.
Battery dip switches: 1 and 5 ON.
https://www.youtube.com/watch?v=enY5UosC9tY
078 443 5272
Hi, I tried to find details on the company but I didn't turn up anything immediate/concrete.  Can you clarify?  I did find the following, but seems to probably not be the above.
http://navitasholdings.co.za/
Thanks.
On 2023/02/02 at 2:34 PM, Chris_S said:
Does that affect warranty? I'm doing a DIY but getting an electrition to do the coc. I know he has installed a lot of sunsynks but is not on the list.
Thank
I've attached an (probably outdated) brochure that I have.
I've seen their battery's at quite a few houses on the west coast and also saw the same batteries in use at Montagu caravan park.
So far at approx 190 cycles the batteries have served us quite well.
Apart from selling their own built batteries they also fix broken ones of almost any brands. I can recall seeing Alot of SolarMD batteries in the workshop due for BMS repairs when I went there to collect my batteries.
Screenshot_2023-07-26-17-14-22-97_f541918c7893c52dbd1ee5d319333948.thumb.jpg.3ef91acebce6eb913682816c11d79179.jpg
Thanks.
We've had the batteries for about a year now. Still going strong.
Thanks.
Funny you did not get anything.
Go to www.felicitysolar.com for their products.
  • 4 months later...
To all the "Navitas"-Custumers;
This might help:
Seplos 48v 150A 8S-16S BMS - Navitas.pdf
  • 5 months later...
Hi All, I bought 2 batteries from Navitas Stellenbosch. I've had it since July 2022 and they are on 1222 and 1072 cycles.
the one does not charge good any more and I cannot get hold of Dricus. Even his number is not available on the network? Does anyone have a new number for him?
  • 8 months later...
Hi Frans
Navitas se deure het toe gemaak
Jammer, ek het ook al probeer om Dricus in die hande te kry
If anyone can help me with the pinouts to make up a battery communication cable between Navitas Battery and Axpert Inverter, it would be much appreciated!
  • 5 months later...
