August 24, 20224 yr What RCD do you guys use to power your inverters? I had and 40A 30mA AC but it tripped when I power the AVAC, the seller told me to use a 300mA and it works but researching about it I must not use an AC the minimum should be F. So I'm planing to buy one F but don't know if a 30mA will work or if I have to use a 300mA.
August 24, 20224 yr In front of the inverter I have an RCD type B 0,03A and works as intended. The Type B is imposed by local electrical company.
August 24, 20224 yr Author 5 minutes ago, Jaxone said: In front of the inverter I have an RCD type B 0,03A and works as intended. The Type B is imposed by local electrical company. Makes sense an B and is a must if you use 3 phases. Thanks I have my answer, will go for a 30mA.
