Deye 12kw 3-Phase inverter MPPT question
Good day Gents,
Everything has been running smoothly without any alarms or trips from the inverter. It's been smooth solar sailing.
@Ross Muller Maybe you have some more info to share regarding why you asked the question?
The MPPT Range is max. 800V. So this then means 595V should be safe. BUT then reading the maximum PV Input Voltage which is 1Kv as @P1000 has stated, won't the combined Voltage be more than the 1000V?
Or is the 1kV rating per string as well?
  • 5 months later...
