October 16, 20223 yr Good moring.. I have a RCT-AXPERT 5K and a Kodak OGX5.48 that i want to parallel. Now my question is, is there any match firmware that wil work because the one use U1-71 range and the other one use U1-72 range
October 16, 20223 yr Doesn't matter as long as they both have the same firmware. I must also add that flashing firmware is a process that can damage the inverter & make it useless. Because one of the machines is a Kodak I would take it to Segen Solar & request a firmware update to match the RCTs firmware. They will do it for you at no cost especially when you tell them it's due to a parallel operation attempt. Best of luck.
October 16, 20223 yr 4 hours ago, Cobusv said: I have a RCT-AXPERT 5K and a Kodak OGX5.48 The Kodak OGX5.48 is an Axpert MKS II, with a high PV voltage Solar Charge Controller. I don't know what the RCT-AXPERT 5K is; does it have 145 V max SCC, or 450 V? If it's the former, then these are two completely different beasts and can't use the same firmware, and therefore can't be paralleled.
