October 22, 20223 yr Hi there, I had a backup system put in and my power consumption is now doubled, is it correct or is there a setting that must be changed. Please help.
October 22, 20223 yr 3 hours ago, eddiepap said: Hi there, I had a backup system put in and my power consumption is now doubled, is it correct or is there a setting that must be changed. Please help. If this happens a part of the reason might be constant discharge of battery and recharge. Puzzled why it went up so high.
October 23, 20223 yr On 2022/10/22 at 2:45 PM, Scorp007 said: If this happens a part of the reason might be constant discharge of battery and recharge. Puzzled why it went up so high. Depends also on how the battery was setup, if done with Voltages vs BMS.
