November 1, 20223 yr On EASun FTP hosted by Voltronic, I just found 2 new files. I can't open one (firmware 74.03 with SN password protected) but the second one seem to be a new version of remote panel firmware but I don't know concerned models. Can someone investigate ? Remote Panel_Reflash_MCU(38.06).rar
November 2, 20223 yr On 2022/11/02 at 9:59 AM, sharkut said: On EASun FTP hosted by Voltronic, I just found 2 new files. Well spotted. I only saw the one recently. On 2022/11/02 at 9:59 AM, sharkut said: I can't open one (firmware 74.03 with SN password protected) Ah. The password turns out to be one that they commonly use. It appears to be an Axpert MKS IV firmware, but a special one for the Pakistani company Inverex (it has no QGMN or QMN commands, but has a QMD command that has "INVEREX" in the response). So for most of us, there is nothing to see there. [ Edit: but later I realised that it's INVERTEX, not INVER EX. Still, the lack of QGMN or QMN commands is weird. So I have no idea what this firmware is for. Except that from the first 4 digits of the serial number (9633), that suggests either Axpert King II or Axpert MKS IV or possibly Axpert VM IV, but all of these should have one of QMN or QGMN. ] Quote but the second one seem to be a new version of remote panel firmware but I don't know concerned models. Can someone investigate ? That sounds like a job for Coulomb 😎 There are so many displays and so many models. My best guess is that this is either for Axpert MKS IIIs (with the removable display), or the MKS IV (with the non-removable colour display and LED ring). There will be differences between the two that can be spotted, but I haven't chased those down as yet. All I can rule out is that it's not for any King models. I'll plod along as I find the time. For technical reasons, display firmware is a little harder and slower than most main firmwares. Edited November 3, 20223 yr by Coulomb
November 3, 20223 yr Re 73.03: On 2022/11/02 at 1:57 PM, Coulomb said: It appears to be an Axpert MKS IV firmware, but a special one for the Pakistani company Inverex (it has no QGMN or QMN commands, but has a QMD command that has "INVEREX" in the response). I didn't realise that actually all the latest firmwares have this QMD command, and the string is INVERTEX, not INVER EX. It might be a typo, but maybe it has nothing to do with Inverex. Edit: So I have no idea what this firmware is for. Except that from the first 4 digits of the serial number (9633), that suggests either Axpert King II or Axpert MKS IV or possibly Axpert VM IV, but all of these should have one of QMN or QGMN. Edited November 3, 20223 yr by Coulomb
November 4, 20223 yr This is Display Firmware for IGrid SV IV V80.26. In Directory Remote panel-3573-220926 pw12345678 Edited November 4, 20223 yr by Michael_Germany
November 4, 20223 yr 5 hours ago, Michael_Germany said: This is Display Firmware for IGrid SV IV V80.26. Ah yes, I had categorised 80.25 as also being an IGrid SV IV display firmware. Thanks for the confirmation. Quote In Directory Remote panel-3573-220926 220926 is presumably the date that the firmware was compiled. Any idea what the 3573 number means? I thought perhaps the model code that appears as the first 4 digits of serial numbers, but all that I have collected start with the digit 9. The next 4 digits of serial numbers are year and month of manufacture, so that sort of ties in but also doesn't as serial numbers don't have a day-of-month.
November 5, 20223 yr 19 hours ago, Coulomb said: Ah yes, I had categorised 80.25 as also being an IGrid SV IV display firmware. Thanks for the confirmation. 220926 is presumably the date that the firmware was compiled. Any idea what the 3573 number means? I thought perhaps the model code that appears as the first 4 digits of serial numbers, but all that I have collected start with the digit 9. The next 4 digits of serial numbers are year and month of manufacture, so that sort of ties in but also doesn't as serial numbers don't have a day-of-month. All of my serial starts with SN96132……. Edited November 5, 20223 yr by Michael_Germany
November 5, 20223 yr 5 hours ago, Michael_Germany said: All of my serial starts with SN96132……. So those would all be Infinis (on-grid models), manufactured since 2020.
November 5, 20223 yr I have 3 IGrid these are hybrid. They can be off-grid as well as on-grid and they can feed into the grid. Optionally via a parameter. Are from this year. However, I still have the problem that I can not upload the firmware for the main CPU. About the rs232 can only update the display firmware.
