November 9, 20223 yr My 5 kW Sunsynk use to limit my PV input to 6500W. Seems after a firmware update I can now set the max PV value on the inverter(Do not know if it was possible before). So out of curiosity it upped the value to 7500W. Anyone else seen this before? Can the hardware cope with it? MAIN:3380-0513 HMI:0000-E424 Result:
November 10, 20223 yr It was not from the firmware update , they have been able to do this from the start."So out of curiosity it upped the value to 7500W" I did the same 🤣 I changed it back to 6,5kw though as i dont realy need that extra power and ofc out of concern if the hardware can handle it .
