2 Different brands Lithium Ion Parallel Connection
27 minutes ago, Terrabite said:
Can you connect 2 Different brands of Lithium Ion Batteries in Parallel i.e Fusion 4.8kw and Dyness 4.8kw ?
Correct answer, only if both batteries are the same  chemistry, presumably LiFePO4 and they each have the same amount of cells and thus the same voltage specs. Most likely communications won't work and thus you'd have to use them in Voltage mode...
Who needs comms 🤣
