November 10, 20223 yr Can you connect 2 Different brands of Lithium Ion Batteries in Parallel i.e Fusion 4.8kw and Dyness 4.8kw ? Edited November 10, 20223 yr by Terrabite Spelling
November 10, 20223 yr Short answer: Depends Longer answer: Depends on a few variables,and your appetite for tinkering. Not ideal for the average home plebby
November 10, 20223 yr Author Thanks PsyWulf, I will then buy same brand Battery and sell the other one.
November 10, 20223 yr 27 minutes ago, Terrabite said: Can you connect 2 Different brands of Lithium Ion Batteries in Parallel i.e Fusion 4.8kw and Dyness 4.8kw ? Correct answer, only if both batteries are the same chemistry, presumably LiFePO4 and they each have the same amount of cells and thus the same voltage specs. Most likely communications won't work and thus you'd have to use them in Voltage mode...
November 10, 20223 yr Author Oh I see, Thank you Kalahari Meerkat I will have a look regarding their voltages and amount of cells, yes they are both LiFePO4,
November 10, 20223 yr 1 hour ago, Kalahari Meerkat said: Correct answer, only if both batteries are the same chemistry, presumably LiFePO4 and they each have the same amount of cells and thus the same voltage specs. Most likely communications won't work and thus you'd have to use them in Voltage mode... Who needs comms 🤣
