November 20, 20223 yr 6 hours ago, Gerrit Dreyer said: Hi, why does the power flow numbers not add up on my visual flow diagram The inverter uses some of the power to run itself and there are some losses in efficiency in the overall system
November 21, 20223 yr 20 hours ago, Gerrit Dreyer said: Hi, why does the power flow numbers not add up on my visual flow diagram Can you give an example?
