November 21, 20223 yr I monitor my batteries religiously. I spoke to Hubble this morning as I one of my batteries has a cell difference. (Screenshot Attached) When I spoke to Hubble, they said it should not be more than 0.02 volts difference, but then changed to 0.2 volts, and then to 0.15 volts. Mine is sitting at 0.059 I confirmed this with PBM tools too so its not just solarassistants reading. What is the actual maximum this should be and when should I start getting concerned.
November 21, 20223 yr 8 minutes ago, MyproD said: Mine is sitting at 0.059 It is actually 0.049 which is on the consensus limit of 0.05 if one is to believe the technical articles out there. Mine is mostly between 0.02 and 0.025 depending on the SOC. At 50% SOC it is less than 0.01 At full charge or when it gets down to 30% then it shows up to 0.025 max. Check the differential at other SOC levels too.
November 21, 20223 yr Also interested to know. At 100% my difference between highest and lowest cell is 0.048V, at 50% soc it's about 0.01V. My AM2 is at 161 cycles by the way. Edit:Typo Edited November 21, 20223 yr by Mier Typo
November 22, 20223 yr Charts are over last 48 hours Pack 4: 0.014V - 0.065V Pack 2: 0.003V - 0.040V Edited November 22, 20223 yr by system32 Set scale the same
November 22, 20223 yr Author Thank you So seems I am all good! I just want to keep an eye on them and make sure there are no funny things happening.
