slipx Posted February 15, 2023 Share Posted February 15, 2023 I'll send you a pm with the dashboard Quote Link to comment Share on other sites More sharing options...
cp2023 Posted February 22, 2023 Share Posted February 22, 2023 @slipx would you be able to send to me as well? Looks awesome! Quote Link to comment Share on other sites More sharing options...
slipx Posted February 22, 2023 Share Posted February 22, 2023 3 hours ago, cp2023 said: @slipx would you be able to send to me as well? Looks awesome! Sure check PM Quote Link to comment Share on other sites More sharing options...
JTUBB Posted March 3, 2023 Share Posted March 3, 2023 On 2023/02/11 at 6:01 PM, mzezman said: Does Olarm NOW have an API for HomeAssistant? Please share your progress and how it looks? I left Olarm for this very reason - it took so long for them to release the API Struggling to make sense of the various pieces on the other forum, but above is a piece of the Paradox Olarm integration that I have managed to cover. There is a slight delay given the polling time on the Rest API. Still a lot to figure out and then to see how it can be used with Alarmo and my Aqara Sensors to create a double alarm. mzezman 1 Quote Link to comment Share on other sites More sharing options...
JTUBB Posted March 5, 2023 Share Posted March 5, 2023 On 2023/02/13 at 7:48 AM, crash said: Can you shell out some code for some of this, specifically the SOLAR / BATTERY / AC round graphs at the top Ditto slipx if you would be so kind. Quote Link to comment Share on other sites More sharing options...
JDSym Posted March 7, 2023 Share Posted March 7, 2023 On 2023/02/15 at 6:18 PM, slipx said: I'll send you a pm with the dashboard Hi slipx I would love to see the code as well please if you don't mind. Are you using an ESP32 running ESPHome to connect to the inverter? I'm still using a Pi running node-red and pushing the data to home assistant via MQTT, but I'm thinking of swopping it out for the ESP32. Quote Link to comment Share on other sites More sharing options...
slipx Posted March 7, 2023 Share Posted March 7, 2023 @JDSym @JTUBB I've uploaded the dashboard to GitHub. I've also added some new views. Remember to install all the necessary components and update your sensor names. I've been using an ESP32 running ESPHOME without issues. https://github.com/slipx06/Sunsynk-Home-Assistant-Dash JTUBB and JDSym 2 Quote Link to comment Share on other sites More sharing options...
