New Home Automation Setup Advice
On 2023/02/11 at 6:01 PM, mzezman said:
Does Olarm NOW have an API for HomeAssistant? Please share your progress and how it looks? I left Olarm for this very reason - it took so long for them to release the API
image.png.6faf8870665c79f11b34b6625321a8ae.pngimage.png.dfb8ea93faa250864e3e31b165629243.png
Struggling to make sense of the various pieces on the other forum, but above is a piece of the Paradox Olarm integration that I have managed to cover.
There is a slight delay given the polling time on the Rest API. Still a lot to figure out and then to see how it can be used with Alarmo and my Aqara Sensors to create a double alarm.
On 2023/02/13 at 7:48 AM, crash said:
Can you shell out some code for some of this, specifically the SOLAR / BATTERY / AC round graphs at the top
Ditto slipx if you would be so kind.
On 2023/02/15 at 6:18 PM, slipx said:
I'll send you a pm with the dashboard
Hi slipx
I would love to see the code as well please if you don't mind.
Are you using an ESP32 running ESPHome to connect to the inverter?
I'm still using a Pi running node-red and pushing the data to home assistant via MQTT, but I'm thinking of swopping it out for the ESP32.
