January 19, 20233 yr Do any of you know what detection mode under advanced settings does? I have set mine to full wave detection as i assume it detects the surge when loadshedding ends and cuts those out as it is running on batteries at the time I see you can get meters for your db board that cut off the power for a certain time and then restore the power Do any of you have surge plugs on your refrigerators? I am thinking of putting them on my 5 fridges as i have a ups on my computer and modems and every time loadshedding ends the ups kicks in for a few milliseconds so there was definitely a surge or voltage drop coming thru when i had the detection set to support voltage ride thru Still busy checking if the full wave detection does anything Loadshedding just kicked in and the ups still kicked in for a few milliseconds so i guess the full wave detection doesnt do what thought it did I see you can get surge arrestors 20Kva and 40Kva I wonder if one of those would maybe help for the surges? Another thing that used to bother me is under diagnosis message i have a posting of: SOC delta over range Please check the settings for battery capacity and charge voltage But this has been like this for 4 years and one of my neighbours who has the same system with a us3000 battery has the same message, so i have just ignored it as i just picked the standard pylontech 2.4Plus x4+ setting Also i have changed my safety settings to 50Hz Default as the South Africa setting kept restarting my inverter ,i think bacause the voltage is so high here 240v-250v Edited January 19, 20233 yr by paul99
January 19, 20233 yr Full wave detection will do overvoltage and undervoltage protection, half wave is faster, but disables one of the two, I can't remember if under or over voltage. Voltage ride through should be avoided in your case. Only have one proper surge arrester at the grid input on your DB. Too many of those plugs will cause earth leakage problems. 50Hz default will disable some safety features and make your inverter non-compliant to NRS097. 26 minutes ago, paul99 said: SOC delta over range Don't worry about that.
July 24Jul 24 On 1/19/2023 at 8:27 AM, P1000 said:Full wave detection will do overvoltage and undervoltage protection, half wave is faster, but disables one of the two, I can't remember if under or over voltage. Voltage ride through should be avoided in your case.Only have one proper surge arrester at the grid input on your DB. Too many of those plugs will cause earth leakage problems.50Hz default will disable some safety features and make your inverter non-compliant to NRS097.Don't worry about that.Sorry for replying on old postBut what about ( no detection ) option Will it be much faster to response to grid outages and act as ups ?
