Solar Assistant Orange Pi
I got a replacement Solar Assistant Pi but with start up it only starts up with the orange Pi logo, no Solar Assistant.
i did a restore from my profile via SD card.
it only allows you to run in trail mode for 7 days before restoring your old profile.
Two questions
will the software now only be on the SD card and not be imbedded on the Orange FDCF18D2-8C83-443B-81C3-7773D5244390.thumb.png.1b393324b4b56313d1d04d598cdbd4c3.pngPi anymore?
will the issue with the battery totalizers correct itself once my full profile is active again?
  • 1 year later...
@Deon Zeelie
A year and 2 days too late...I'm sure you got it right by now!
For completeness, after confirmation that the trail license is working ok, one needs to go to https://solar-assistant.io/sites, click "Edit" and then "Swap License".
No the SA software will not be embedded. I really think SA could have put in a option in this SW version to copy it from SD to Memory. Not difficult to do, if one had access to a terminal. Maybe someone with above average linux skills could experiment and see if this is possible.
I' would assume that if you had made a backup of your data, the history would be OK, but i think the backup feature only became availabe on SW version date
2023-08-16.
PS all, I have a spare Orange Pi 3 LTS and SA on SD card available. PM me if you are in Centurion area.
