January 27, 20233 yr Good morning, thank you for accepting me. I have a battery with BMS Seplos for 16 cells and an Aspect VMIII voltronic inverter, configured on 05 for Pylontech battery. When the battery reaches the discharge voltage and the inverter goes into line mode and starts charging the battery, an error 71 appears on the inverter screen. I can't find what that error is and it appears in the manual. Could you help me?
January 27, 20233 yr Author Ok, in my manual it only goes to error 59. It has been a great help. Let's see if I can now locate why this happens Thank you..
January 27, 20233 yr 3 minutes ago, fmatute said: Ok, in my manual it only goes to error 59. I think you'll find the other fault codes are in a different section of the manual, as they relate to BMS connection only.
January 28, 20233 yr Author In the manuals that I have there is no section of the BMS. It only refers to configuring some type of battery. I try to find information about the different parameters of the Voltronic Inverter for Pylontech batteries, or Lib, because I only get communication between the BMS and the inverter in the 05 Pyl position.
