February 11Feb 11 On 2026/01/05 at 10:23 AM, CobusK said:This is the logger module. Unplug the white multi-pin plug from the board. If the LCD comes to life, the board is US. It is normally the C9 resistor that goes. The replacement board is about R250.00 from Deye service centre. I just replaced a couple.Thank you, definitely experienced this issue 6 months ago, cant remember if i unplugged it , you can access this board without breaking the seal on the side.ill buy a couple of these
February 16Feb 16 On 2026/01/05 at 8:26 PM, sorts said:Thank you so much, guys. I have removed that connection, and the screen and rs485 communications are working again.Happy new year from Valencia, Spain.HI there, what is the part number? im gonna order 2or what do i request from themn?thanks
April 14Apr 14 On 2026/02/16 at 7:41 AM, guyi9000 said:HI there, what is the part number? im gonna order 2or what do i request from themn?thanksHI guys part number?how do we order online or at deye in SA?Thanks
April 27Apr 27 On 2026/01/05 at 3:23 AM, CobusK said:This is the logger module. Unplug the white multi-pin plug from the board. If the LCD comes to life, the board is US. It is normally the C9 resistor that goes. The replacement board is about R250.00 from Deye service centre. I just replaced a couple.Where can I find the replacement module?
July 20Jul 20 On 2026/04/27 at 1:54 PM, soapsipo said:Where can I find the replacement module?i also wnat to buy two of these? where? deye jhb does not repsond when you msg them
