Problem with Victor Max 10.2 Kw
Has anyone measured voltage between neutral and ground on this inverter (3 measurements .. one with grid connected but on battery/solar output, one with bypass and a third one without grid connected).... a friend seems to have a serious problem with this one as it measures 110V between N-E and RCD does not trip! Any solution?
  • 1 year later...
  • Replies 51
  • Views 22.6k
  • @Talino8I bought it from Curley Wei Via Alibaba. unfortunately i dont have Panels yet, only planning to add them soon.
  • Okay i get you. i had to contact my battery manufacture and they gave me settings to use on the inverter since there is no communication between the inverter and the battery and so far seems to be wor
  • Thank you. When it comes to the main issue of the inverter disconnecting the PVs, it seems to happen specifically when there's a voltage drop in the PV array and the available energy is low. T
Hello Sirs!
I have this 10.2Kw too. I want to feed the grid. Now I dont have battery, made the configuration to feed.
I wired only the AC IN. Not the main out, and slave out.
Seems working ok, but on the display it shows utility bypass. Dont know why.
What you think? I have to link the AC in and the MAIN OUT? Or how?
