Sunsync inverter in parallel
2 hours ago, rob1 said:
So if you parallel inverters, would you lose out by having all panels on one vs shared across two?
No, the available pv power will still be shared, albeit indirectly.  Remember your battery bus is common to both inverters. The acess pv power that is available on the inverter with PV will be made available as battery charge power. The inverter with no pv input will demand power being drawn from the battery, causing the charge power from inverter 1 to be consumed. This is of course possible if the battery is already full and does not consume the charge power.
EDIT :   this explanation may or may not be applicable where power is exported via gridtie non essential connection.
Edited by BritishRacingGreen
