OG 3.24 solar first low watt
Hi all using solar assistant to monitor settings, when on solar first
- uses more grid than pv eg for load of 137w uses grid 273w and pv only 17w
- if I switch this this to solar battery utility then this works as expected
- 157w load pv 149w grid uses 0
I would leave this on SBU but when solar stops say 5pm the batteries are low and then I’m afraid I’ll delete the batteries to 0 does not look like it even uses the utility in this mode
Is there a setting somewhere ?
thanx in advance
Ok.
Go to the config tap
Change the following settings.
Back to battery voltage and back to grid voltage.
If I am not mistaken this will unfortunately engage grid to charge you batteries during the day as well.
