April 16, 20233 yr Hi gents, I pulled the trigger on this inverter + battery, should be installed next week. My question is, is there is an app that I can download to monitor battery % during/after load shedding? That's the only reason I would want the app, just to monitor battery health.
April 17, 20233 yr 4 minutes ago, Olorin said: Anyone? what battery will you be employing , Lead Acid or Lithium , and if Lithium , what make?
April 21, 20233 yr Hi @Olorin I would take a look at the Hubble Cloudlink : https://segensolar.co.za/product/hubble-lithium/storage-systems-hubble-lithium/communication-module-storage-systems-hubble-lithium/remote-monitoring-module-for-hubble-lithium-batteries/ This device will allow you to track and monitor your entire system on their custom app and assist with BMS control functionality too. I hope this helps.
June 7, 20233 yr On 2023/04/16 at 12:20 PM, Olorin said: Hi gents, I pulled the trigger on this inverter + battery, should be installed next week. My question is, is there is an app that I can download to monitor battery % during/after load shedding? That's the only reason I would want the app, just to monitor battery health. You wont be disappointed with https://solar-assistant.io/. I've been making use of it for a while and it works great. *Can monitor the inverter & battery remotely with a neat looking app (can also be installed as Android / IOS app). I have a Pylontech battery and needed an additional cable to get more stats.
