Deye inverter control Smart Switch
Good day,
I would like to know if the Deye inverters be set up to control a smart switch only when there is excess pv power available?
Example: only power ac air conditioner unit (via smart switch) when battery is full and pv > total ac loads?
Thank you
17 minutes ago, Jack007 said:
Good day,
Thank you
I was going to say no but the Aux / Smart load function kinda does this. It doesn't turn the switch on per se - it just powers the unit from PV as opposed to grid - you could look into that.
Its probably better to get into something like Home Assistant that will allow you to do this and much more throughout your home
