May 12, 20233 yr 23 hours ago, Adagio said: "LC1 73 70C" I think you mean "LC1 72 70C". So this is not an LFP flavour. So IF you can update it at all, and you are running an LFP battery, you would benefit from updating to the LFP flavour. You may as well update to the latest version, which is 73.00e.
May 13, 20233 yr Author So I figured it out. It's not hardware, rather it thought the battery was flat because I set the VCO too high in an attempt to prolong my battery life, and the very steep drop off in LIFEPO4s voltageaat the lower end made the inverter think the battery is flat so it didn't try to turn on the booster. @Coulomb Yes. I made a typo there. Youre right Edited May 13, 20233 yr by Adagio
