May 10, 20233 yr Ek het die Vito inverter as iemand iets relatief goedkoops soek om aan gang te kom met loadshedding solution. Dit is basies mecer/voltronic copy met redelike specs vir die prys. R4000 , boks het ek oopgemaak, battery tydelik gekoppel en getoets, maar nooit geinstalleer nie. 24V stelsel so jy gaan 2x 12Vbattery nodig hê of 24V battery pak soos esener 24V 100Ah. 3.5kW 24V Solar Hybrid Inverter Vito / Mecer Main Features Pure sine wave inverter. Output power factor 1. Built-in battery equalization function to extend battery life cycle. Built-in MPPT solar charge controller. Selectable input voltage range for home appliances and personal computers. Selectable charging current based on applications. Configurable AC/Solar input priority via LCD setting. Compatible to mains voltage or generator power. Battery equalization for optimized battery performance and lifecycle. Priority settings LITHIUM Compatable Technical Specifications General Model: SH3524 Rated Power: 3200VA/3500W. Input Voltage: 230 VAC. Selectable Voltage Range: 170-280 VAC (For Personal Computers); 90-280 VAC (For Home Appliances). Frequency Range: 50 Hz/60 Hz (Auto sensing). Output AC Voltage Regulation (Batt. Mode): 230VAC ± 5% Surge Power: 6000VA Efficiency (Peak): 93%. Transfer Time: 10 ms (For Personal Computers); 20 ms (For Home Appliances). Waveform: Pure sine wave. Battery & AC Charger Solar Charger & AC Charger Maximum PV Array Power: 3000 W. MPPT Range @ Operating Voltage: 30 VDC – 400 VDC. Maximum PV Array Open Circuit Voltage: 400VDC. Maximum Solar Charge Current: 80 A. Maximum AC Charge Current: 60 A. Edited May 14, 20233 yr by jlr
May 14, 20233 yr On 2023/05/11 at 12:32 AM, jlr said: Ek het die Vito inverter as iemand iets relatief goedkoops soek om aan gang te kom met loadshedding solution. Dit is basies mecer/voltronic copy met redelike specs vir die prys. R4000 , boks het ek oopgemaak, battery tydelik gekoppel en getoets, maar nooit geinstalleer nie. 24V stelsel so jy gaan 2x 12Vbattery nodig hê of 24V battery pak soos esener 24V 100Ah. 3.5kW 24V Solar Hybrid Inverter Vito / Mecer Main Features Pure sine wave inverter. Output power factor 1. Built-in battery equalization function to extend battery life cycle. Built-in MPPT solar charge controller. Selectable input voltage range for home appliances and personal computers. Selectable charging current based on applications. Configurable AC/Solar input priority via LCD setting. Compatible to mains voltage or generator power. Battery equalization for optimized battery performance and lifecycle. Priority settings LITHIUM Compatable Technical Specifications General Model: SH3524 Rated Power: 3200VA/3500W. Input Voltage: 230 VAC. Selectable Voltage Range: 170-280 VAC (For Personal Computers); 90-280 VAC (For Home Appliances). Frequency Range: 50 Hz/60 Hz (Auto sensing). Output AC Voltage Regulation (Batt. Mode): 230VAC ± 5% Surge Power: 6000VA Efficiency (Peak): 93%. Transfer Time: 10 ms (For Personal Computers); 20 ms (For Home Appliances). Waveform: Pure sine wave. Battery & AC Charger Solar Charger & AC Charger Maximum PV Array Power: 3000 W. MPPT Range @ Operating Voltage: 30 VDC – 400 VDC. Maximum PV Array Open Circuit Voltage: 400VDC. Maximum Solar Charge Current: 80 A. Maximum AC Charge Current: 60 A. @jlr Is the inverter the 3000w model or the 1200w as on the box it has a tick mark as model Sh2012 instead of SH 3524 please let me know as i want to buy it as 24v 3kva model. Edited May 14, 20233 yr by TaliaB
May 14, 20233 yr Author Blerrie chinesse , no for sure the 3kW unit, See pic of side of inverter. Reduced to R3900
May 14, 20233 yr 2 hours ago, jlr said: Blerrie chinesse , no for sure the 3kW unit, See pic of side of inverter. Reduced to R3900 I will take it
